87 GN raditor 3/4-18 INVERTED FLARE 1/2" tube
Originally posted by tom h
The radiator side of the stock oil cooler hoses is a 3/8" Inverted Flare (actual thread size 5/8"-18).
Inv Flare Fittings or adapters in this size can be difficult to find.
The fittings on the oil filter/cooler adapter side are even weirder: 20mm Saginaw fittings, also very difficult to find.
While theoretically you only need 3/8" hose ID, I'd feel a lot more comfortable with a hose ID of 1/2".
If you're using an external oil cooler, I think it's a lot easier to ditch the large Inv Flare fittings and use the more common "AN" 37º flare fittings.
see some pics here:
http://community.webshots.com/album/63093078uJqZEQ
Eaton WEATHERHEAD MAKES an adapter part number C5880X8, ie, 3/4"-18 inverted flare male to AN-8 JIC 37 male.STEEL
you could use 2 or 4, with using two, they would go into the engine oil cooler tank of 86-87 stock style radiator,BY USING STANDARD AN-8 line with AN-8 female hose ends of your choice, THEN , you can connect up with swivel pipe thread hose ends on the engine side .
BY using FOUR (4) of these WEATHERHEAD C5880X8 ADAPTERS, THIS CONVERTS EVERYTHING TO AN-8 HOSE ENDS THAT ARE NEEDS , 2 HOSES WITH AN-8 FEMALE JIC 37 ON BOTH ENDS OF BOTH HOSES, FIGURE OUT WHITCH ANGLE FITTINS WORK BEST FOR YOUR INSTALL.
THe radiator transmission cooler lines are 5/16" OD tube>1/2"-20 inverted flare, plenty of adapters from earls , russell and aeroquip to fit these,
AS far as the 3/8" OD tube> 5/8"-18 size Male inverted flare, IT IS NOT USED ANY WHERE!!!!
HOWEVER, the GM did move up to this size on the ( 5/18"-18 INVERTED FLARE) trasmission cooler lines starting in the early nineties, late eighties models.
REGARDS BLACKHAWK 38
