getchasum
MISSING 2 CYLINDERS???
- May 23, 2002
I''d be interested in hearing some detail as well in an off the shelf 4.1 Stroker.......
SignUp Now!With a set of what I'm building, a rebuild will go like this... First you measure the worst hole and figure out where it will clean up at. Rough hone it to size (no more boring!) and tell me the final bore size. Then, decide what static compression you want using cost effective non custom gaskets. That sets the compression height (no more decking!). As long as the piston isn't too close to the head, that's it!
With our engines, ring selection is going to define the final bores moreso than the instant a block comes clean.
Is Rob Zombie really on this board and owns a GN
Does this include E85 engines?You always do the worst hole first because.... well... that's the worst one.
Engines with power adders need more ring gap to the hotter temps the rings experience. Under operating conditions the gap closes up more than a low HP N/A engine.
