Warp6
Mine since '92
- May 25, 2001
Been trying to diagnose a skip. Thought it was electrical so I tried a few things there. Car would run great until fully up to temp, then it would just start skipping. Did a compression check..160 across the board except #3, 140lbs. Noticed plug was oil soaked too. (I never saw it smoking) I thought it was probably a bad ring. I yanked the engine yesterday and began the teardown. #3 didn't want to come out of the hole. Now I know why...the pin was bound up against the side of the cylinder which left a nasty gouge about an inch wide along the wall. It was built about 5 years ago. Std bore TRWs with stock pins, stock polished rods, TTA crank, RJC girdle. I thought I had a solid bottom-end....WRONG! What could have caused this?
