What's wrong with my car ?
Boostdeznuts
TURBO PART WHORE
Took it out this weekend ,spool up the car and let it rip but then heard a loud pop. pull over and the up pipe came off, drove her home ,put it back on but now she wont Idle, every time I give it gas she stutter and then shut off. check for all vaccum and she no hose pop off. Iac came up to 140 but no code
TIA
You over boosted!!...Hopfully the tube blowing off saved the motor,If you've ran down all your vacume lines an there tight an theres still a miss,you most likly popped a head gasket,Pull your oil dip stick, look for chocolate milk,an or keep close eye on raditor water level,Pull all the plugs an look for differances,Compresion test the best way to go
Good Luck
Bozo
Check ALL the connections. That may not be the only one that got blown loose.
The pop may also have taken out your MAF.
Thanks Dave and everyone else that think it a Maf, I swap out another working Maf and she PURRRR
thx again
