ablackFormula
- Mar 16, 2004
I've posted here a few times and I'm still completely lost. I just finished installing the FAST unit on my stock LT1, and although I can get the car to run, it's very barely and spits and farts whenever you try to rev it up. Letting the car idle for even a few minutes makes my eyes water, and the O2 sensor was locked at 15.94 as a ratio, which is the exact opposite of making your eyes water. So I sent the unit and O2 sensor back, and they told me there was no problem with it.
I just reinstalled it, and the a/f ratio is still locked at 15.94 (I double checked the O2 harness, no shorts/opens/grounds,) I checked for the proper voltages and grounds at the ecu side of the harness, all checks out ok. However, if I rev it up, the a/f ratio will change when I let go of the gas and the engine decelerates back to idle. I have the close loop parameters set. I tried changing the a/f ratio at idle by changing the corresponding cells in the VE table, and when I set the cells to both 100% and 25% I got no change in the way the engine ran. And also, now since I got the ecu back, the gauge on the dash no longer coincides with what the ecu sees for water temp (they did before I sent the unit out.)
When you first finish installing a fast unit what are the first tables you adjust to get it running right? (I copied the spark timing and VE tables from tunercat, so they're the equivalent of stock tables from my original PCM.)
Please send me some helpful responses, I'm lost and don't like it ..
