- Jul 7, 2007
SignUp Now!what could be happening is the wastgate cant keep it sealed all the way when the load increases in 3rd.but then in third went down to 9.2 ..with the extra load of third gear i figured af would be much higher.
yupyou feel 26, is way out of range for the 6766 and 32-34 would wake thing up?
if this is the timing its going to be really lazy17/16
Felt i was being safe with the unknowns of the new turbo...it does respond well to a few degrees more.... " what could be happening is the wastgate cant keep it sealed all the way when the load increases in 3rd" < not sure i get what you mean by sealed all the way" ,,,you mean exhaust pressure is blowing the gate open more ,dropping boost, and making things richer? . but there isnt any boost creep either way? actually,not 100% sure on that one,,,something i can check thoughif this is the timing its going to be really lazy
yesexhaust pressure is blowing the gate open more ,dropping boost, and making things richer? .
give it what it likes,timing lites the fuel and the motor does need to rpm to move the airit does respond well to a few degrees more...
it is i agree,your just on the very low side.you could pull plugs and get an true reading on the chamber.iming is a slippery slope
your welcome.thanks very much for the theory and direction on the base issue ...
