Where to buy new/built motor?
liv4gnz
ok sorry for starting a new post but i hate having to keep scrolling down when it changes to a new topic but
i want to get a new bottom end/long block
the piston was fried and the driver side bank look toasted as well
it has 140k on it and as far as the crank bearings and cam all that ****
i really dont want to just throw another piston where the bad one was
the motor was pretty fine had good oil pressure the block itsleve is perfect
so should i pay to get a stock rebuild done where they bore it and new pistons and all that **** with arps and good new head gaskets
or should i buy that long block from 68 nasty z i think for around high 3k
but thats a roller setup and ported good heads all that
i just want to do it and not look back but than again i want to get only what is needed and not over kill and not spend an arm and a leg
same time im going to do the trans so its gonna be sitting
can you guys give me some suggestions on my situation and what i should do or what do i need? thank you
I think it would be cheaper to send the block to a good machine shop and verify that the block is usable. Then verify the crank is ok, cam.
Verify the heads are ok - but rebuild them
Buy a set of good pistons/rings - stock are fine
What I mean is, if that block is ok, use it. Don't take another one off the market please.
I'm sure there's a good Jersey machine shop close to you that can do this.
You can sleeve the block probably cheaper than buying a new one. A sleeve done right works great too. I've had a sleeve in mine for 2 years now:)
they said it didnt need ot be sleeved bored .30 over with over sized stock pistons and good rings new bearings cut the crank and all that
rebuild the heads
now thats 2100
than figure that other engine is around 3
i just want the best deal and not have to open it up twice
as far as bringing him my own parts
can i put the motor in with the heads attached? and do the studs
and what head gaskets should i give him?
so by tomroow eveyr thing will be completely out and im gonna clean up the whole engine bay
