Where to buy PCV check valve?
So I just bought a PCV1162. If I blow on it from the small end some pressure leaks through. I was thinking it should not do that at all. Is mine defective?
Unfortunately the quality varies a lot these days, and some leak by. They used to seal up pretty well a few years ago.
Should I get a check valve and put it inline to be safe then? I bought this one to replace my AC Delco one that seems to stick open once in awhile.
Take the 1162 back to AutoZone BuickMike, it's defective. Exchange it for another one. Be sure to give it a blow test before you leave the store as I've found you may need to test a few before you find one that seals. I've been running these for years without issue. If you've got a catch can installed, then also install the Kynar (PVDF) 3/8" check valve (US Plastics) , in line to prevent your catch can from pressurizing during boost.
Well, I went to 2 different AZ's to find this one and it was the last they had in the state. They said they can't get them any longer.
Interchange Parts for DEUTSCH PCV1162
Brand Sku Type Name
ACDelco CV924C PCV Valve ACDelco CV924C PCV Valve
BECK/ARNLEY 045-0268 PCV Valve BECK/ARNLEY 045-0268 PCV Valve
LUBER FINER PC175 PCV Valve LUBER FINER PC175 PCV Valve
MOBIL PC175 PCV Valve MOBIL PC175 PCV Valve
WIX FILTERS 66071 PCV Valve WIX FILTERS 66071 PCV Valve
AIRTEX 6P1198 Crankcase Ventilation Filt AIRTEX 6P1198 Crankcase Ventilation Filt
CHAMPION 59250 PCV Valve CHAMPION 59250 PCV Valve
CHAMPION PC142 PCV Valve CHAMPION PC142 PCV Valve
CHAMPION PC175 PCV Valve CHAMPION PC175 PCV Valve
PUROLATOR PV1003M PCV Valve PUROLATOR PV1003M PCV Valve
PUROLATOR PV1014 PCV Valve PUROLATOR PV1014 PCV Valve
PUROLATOR PV1014M PCV Valve PUROLATOR PV1014M PCV Valve
CAM2 P1014 PCV Valve CAM2 P1014 PCV Valve
CARQUEST 76-2511 PCV Valve CARQUEST 76-2511 PCV Valve
CARQUEST 78011 PCV Valve CARQUEST 78011 PCV Valve
CARQUEST 82071 PCV Valve CARQUEST 82071 PCV Valve
CARQUEST V246 PCV Valve CARQUEST V246 PCV Valve
CARQUEST V266 PCV Valve CARQUEST V266 PCV Valve
CARQUEST V268 PCV Valve CARQUEST V268 PCV Valve
CARQUEST V272 PCV Valve CARQUEST V272 PCV Valve
CENEX PC142 PCV Valve CENEX PC142 PCV Valve
CENEX PC175 PCV Valve CENEX PC175 PCV Valve
CITGO PC175 PCV Valve CITGO PC175 PCV Valve
COBRA WCV207 PCV Valve COBRA WCV207 PCV Valve
DEFENSE FV275 PCV Valve DEFENSE FV275 PCV Valve
DEUTSCH PCV138 PCV Valve DEUTSCH PCV138 PCV Valve
DEUTSCH PCV162 PCV Valve DEUTSCH PCV162 PCV Valve
ECHLIN 2708671 PCV Valve ECHLIN 2708671 PCV Valve
ECHLIN Feb-16 PCV Valve ECHLIN 2-9316 PCV Valve
ECHLIN 40590 PCV Valve ECHLIN 40590 PCV Valve
ECHLIN CRB29316 PCV Valve ECHLIN CRB29316 PCV Valve
ECHLIN CRB29336 PCV Valve ECHLIN CRB29336 PCV Valve
FILKO P-229 PCV Valve FILKO P-229 PCV Valve
GRAND PRIX PC175 PCV Valve GRAND PRIX PC175 PCV Valve
GRSE MNKY P1014 PCV Valve GREASE MONKEY P1014 PCV Valve
HASTINGS HV106 PCV Valve HASTINGS HV106 PCV Valve
KRALINATOR V231 PCV Valve KRALINATOR V231 PCV Valve
LUBER-FINER PC142 PCV Valve LUBER-FINER PC142 PCV Valve
LUBER-FINER PC175 PCV Valve LUBER-FINER PC175 PCV Valve
MIGHTY 61016 PCV Valve MIGHTY 61016 PCV Valve
MIGHTY 6-700 PCV Valve MIGHTY 6-700 PCV Valve
MIGHTY PC142 PCV Valve MIGHTY PC142 PCV Valve
MIGHTY PC175 PCV Valve MIGHTY PC175 PCV Valve
MILEGUARD DV275 PCV Valve MILEGUARD DV275 PCV Valve
MILEGUARD FV275 PCV Valve MILEGUARD FV275 PCV Valve
NAPA 15373 PCV Valve NAPA 15373 PCV Valve
NAPA 18295 PCV Valve NAPA 18295 PCV Valve
NAPA 18323 PCV Valve NAPA 18323 PCV Valve
NAPA 2708671 PCV Valve NAPA 2708671 PCV Valve
NAPA 2708700 PCV Valve NAPA 2708700 PCV Valve
Also, O'Reilly has it listed as a Microguard PVC275. I cross referenced what cars these came out of. It looks like the one to look for is a 1992 Mazda MX-6 GT with a 2.2 liter turbo.
Update. AZ found another PCV1162 and it leaked as well. We looked it up by vehicle and found that the new Luber part number is PCV1138. I grabbed one of those and it was fine. It is the exact same size. It sealed up nice for boost and regulates less air than the AC Delco I have now. I wonder how my BLM's will look. Not that they are an issue now.
