RJC has one check this out RJCRacing The leaders in Buick Performance and Innovation
If you scroll down it is for sale under the deal of the month. Good luck:smile:
Wow I did not know that the aftermarket PCV valves did that. I guess I got lucky because I did exactly what you said, I left the stock PCV in place and added the aftermarket one as a one way check valve.
Go to Autozone, get PCV 1162. Works well as a check valve, less oil consumption. It's a tad shorter but the stock hose still seems to work ok.
I have found these to be better than the stock PCV for BLM consistency.
So ummm yeah which one of these do we use or are they the same just one is from autozone? and do we add the check valve that jay suggeseted to the pcv or in place of the pcv ?That's the one part you DO NOT want to use because as you can see by it's design and description it's designed to replace the stock PCV.
Many folks can tell you from experience it will not work properly in that configuration. It will work fine if used in line WITH the stock PCV. It has virtually an unregulated amount of flow in the vacuum direction which will drive you nuts trying to tune around the whacked out BLM's resulting from using this device.
The stock 893 PCV is the best to use and is calibrated for the PROPER amount of vacuum bleed for these turbo cars. Not just any PCV will work either.
I get so many people coming in trying to figure out why their BLM's are not as they should be, after they've checked for vacuum/exhaust leaks till they're blue in the face!!! I look down and see one of these stupid check valves in place of a good PCV. Rip it, put a few dollar 893 PCV in and their tune goes straight to normal.
