Go to Autozone, get PCV 1162.
Is this a Delco # ?
SignUp Now!Go to Autozone, get PCV 1162.
Go to Autozone, get PCV 1162. Works well as a check valve, less oil consumption. It's a tad shorter but the stock hose still seems to work ok.
I have found these to be better than the stock PCV for BLM consistency.
+1 on thanks for the tip. Is this the right part? I've been chasing a BLM issue.No, its the Autozone brand number. I think its "Luber Finer" brand.
so do u use this along with the one they sale for our cars pcv 1126 or only pcv 1162 by itself
Use the pcv 1162 only, unless you have the brass aftermarket check valve then you would / or could use both.
If im not mistaken the numbers are transposed i think its #1126 the 1162 posted looks nothing like anything for our cars...hopefully someone will chime in that knows....http://www.autozone.com/autozone/parts/PCV-Valve/_/N-8gd7h or .....http://www.autozone.com/autozone/pa...2&fromString=search&isSearchByPartNumber=trueGo to Autozone, get PCV 1162. Works well as a check valve, less oil consumption. It's a tad shorter but the stock hose still seems to work ok.
I've used the UsPlastic Check Valve for years and just recently swapped out my Kirbans with it and it solved a few issues I was having. It has a 1/2 lb cracking pressure. Part # 64175, the Kynar ones can handle heat better.
Which way should these valves be installed? Flat side to vacuum block or PCV?
On the body of the check valves from USplastics there is a small arrow. The arrow will be pointed inline pointing toward the vacuum block. Showing flow to the block but closing under boost when the lines are charged.
