How many threads are you burning?I'm currently using the coldest NGK plug I could find for my application, a -11. With the E-85 I run 36 deg timing and 9.25:1 at idle and end up at 26deg timing and 6:1 at 311kpa. EGT's are in the 1300* range. Rich enough, you think? Wait till you see the new E85, turbo, 6 liter LS sleeper project that's in the works:smile:
Have you cut the ground electrode back further than how they come in the box?
Not sure what a good egt for ethanol is, but 1300 with methanol is living dangerously on the edge.
What are you using for an O2 sensor? Does it really read that low? I would think that for a stoich of 9:1 and no intercooler, you should be closer to 5:1?
Give it up. Inquiring minds want to know.
