greeneyegi
- Feb 21, 2010
im finally ready to step up a level and go with an alky kit.ide like to know from fellow tr owners the best alky kit for our cars.how many differentbrand are their?i want the best.thanks guys
i want the best.
I'm partial to the trunk mount Cooling Mist kit, Adjustable with a lap top, or the control knobs on the controller. And the alky is away from possible ignition sources. Alky stays way cooler, and it works as well as a Razor kit, which is a good kit as well. Julio should look into marketing a trunk mount kit. It holds 1.5 gallons of go fast juice.
Most will say an alkycontrol kit from Julio!! great costomer service it's a progressive kit and it works!!
ive got new tt chip match 60 lb injctrs,walbro fp,all the typical stuff,everything works great ,so i figured alky is best next step,im in n cali,dont know how easy to get juice tho
We keep getting Nasty Grams from our local track because we run too fast on pump gas and alcohol. 10.12@136.
Alkycontrol for the win. Nothing saying you can't mount something in the trunk for a reservoir. Julio supplied me with longer harnesses for the pump, longer supply line and a check valve. Mounted the pump out back with a Metco cell where the spare tire goes. Check it out...... http://www.turbobuick.com/forums/al...tech/305551-metco-fuel-cell-install-pics.html
