toofastforyou
2FAST4U
- May 25, 2001
I'm a little confused here...Stock front springs here, 1.2x 60fts regularly. Like Billy said put your money in shocks. You don't need front springs unless you are trying to change ride height. I run QA1 coil-over rear springs, they do fit in the stock location. A good setup in the rear is to use the wolf racecraft or trz adjusters at the axle side of the rear spring so you can adjust ride height.
Claude :redface:
