toofastforyou
2FAST4U
- May 25, 2001
I'm a little confused here... What's the difference in performance between using regular type coil springs in conjunction with QA1 12-position adjustable shocks vs. QA1 coil-overs? Is there one setup better than the other? Also does that mean that when using coil-overs, you don't need any regular shocks anymore? Maybe a picture or two would help me to understand better...Stock front springs here, 1.2x 60fts regularly. Like Billy said put your money in shocks. You don't need front springs unless you are trying to change ride height. I run QA1 coil-over rear springs, they do fit in the stock location. A good setup in the rear is to use the wolf racecraft or trz adjusters at the axle side of the rear spring so you can adjust ride height.
Claude :redface:
