C
coach
Guest
Hey Guys,
Dont know if this question has a direct answer, but here goes. Which of the 67mm or bigger turbos has the best overall powerband? I have read that a Te45a really likes high boost( 26-30) to come alive and performs kinda slouchy below 26 pounds. So if I were to run it at 20-22, it would probably not seem like a good turbo. Is there a turbo that just makes great power at any level? Lets say you havent done your bottom end yet, but were going to. You are only going to buy one turbo. Which one could you buy and run on your stock bottom end and then just turn loose on a properly built and girdled bottom end? Am I making sense? Lets use a 3200 stall lock up for the convertor choice.
Coach
Coach
