Which Upper Plenum for a Stage 2 Intake
blackgn1
Set on TSM Boost
What upper plenum will work with a Stage 2 off center intake? Thanks for any help.
Norbs! Thanks. I thought it was the 4150. What throttle body are you going to use on you build?
I a using the accufab 90 MM unit, its more than enough...You will have to make a custom throttle cable bracket no matter what..
Contact Mike E on this board, or search his postings. He made me an upper plenum and it was sick!
Edlebrock. Wilson. 6061. Is there a difference? Edlebrock is alot cheaper. 6061 looks better. Wilson looks good and is a little more expensive. Is there a difference in air flow? Too many choices.
The only difference between any of the elbows is airflow distribution. The more airspeed you have the worse the problem. The right size charge tube and throttlebody for your hp affects this more than the elbow does. If you have a big plenum under the elbow that helps with distribution.
Basically, pick the one that fits the best and has the throttle cable mounting you want and you'll be fine.
