SignUp Now!So are you getting good atomization with the M15 nozzle and the newer style pump?
hmmm. Maybe it's a good time to see what injecting after the turbo does???
You will need a lot more pressure and a way to get it into each cylinder evenly. Much easier before the turbo.
If you can cool the system down enough before the turbo, why mess around after? You can inject more than enough there.
Extreme boost conditions Rich. I'm thinking the system would work if you decide to run 20+ PSI and instead of shooting it to the side shoot it from the front of the foot into the pressurized A/F mix to help it atomize as well as even out the cylinder balance some. Use it as a secondary enrichment to keep the mix fat enough to prevent detonation.
   I WANT RESULTS:tongue:
  I WANT RESULTS:tongue:Well Charles, beings you are messing around with intakes better get to work. Someone needs to figure out the best point in the intake to inject alky and have it equally distributed. Shouldn't be too tough
In the meantime, I think Rich's car would be an excellent candidate to try your hybrid turbo onI WANT RESULTS:tongue:
Hope you have a good night Jesse. Glad I don't work like that anymore though.
 The job's isn't THAT bad, and for what I get paid, I can handle a few off shifts:wink:
