Boostnitup
- Feb 20, 2002
Bottlefed
What did you use for engagement of the two stages?
I was given a suggestion to utilize a Casper's rpm conversion switch to engage the first stage. Evidently this is an item Casper's offers in converting the tach signal for usage in rpm related items.
I would assume a manual engagement switch of some sort could also work. (If there is a way to mount it on the '87 Intake?)
My one concern was fuel/nitrous oxide atomization within the upper intake. I pointed the nozzles up to shoot toward the roof of the upper doghousing and slightly forward to spray into the air stream (hoping this will distribute everything evenly with the incoming airflow).
Your fuel system... are you using a dedicated system for the nitrous? Or... are you coming off the fuel rail?
btw... you can reach me at Boostnitup@yahoo.com (I have a bunch more questions!)
