redhotrod
Turbo Happy
- Nov 19, 2002
Hi guys,
I just got done rebuilding my 700r4 for my truck, 1st transmission I ever did, I followed the ATSG book step by step and was very confident it would work. Well, it goes in all gears good but after about 5 minutes of running, it started making a whining/whurring(like gear drive, bad power steering) noise. I shut the motor off after about 1 minute of that, I'm hoping the fluid will "soak in" to quiet the tranny. But maybe it needs to get up to temp first? I dunno. I just don't want to ruin it.
The invested parts in this project is a 1991 700r4, new tcc solenoid, borg warner clutches, band, steels, transgo jr shift kit, corvette servo, .500" tv valve, new updated regulator valve, and new precision torque converter. I filled it with dextron III, 6 quarts before firing it up, 3 quarts after, 1/2 quart in converter before install. I also used transgel assembly lube during the rebuild on most parts. Could that be clogging something till it warms up?
And will it be safe to run it till it warms up, or should I take it apart and see whats going on? I have installed lots of fresh trannies and never heard this sound before. Scares me because this is my 1st rebuild of my own.
