stock high mileage GN, white smoke billowing out of the exhaust on the highway, close to home, so got her back in the garage. Took little over a litre of oil to top back up what was lost. oil in intercooler, TB also some pressure had built up oil was inside engine compartment, noticed the dip stick had popped up, also vaccum to turbo had popped off.
cleaned up engine ran it after all the smoke from the degreaser burned off, didn't see any visible oil leaks, no burning smoke, also no oil on ground. when driving still gives some white smoke, more as you drive faster and add a little boost.
took off turbo shield to see if anything was leaking from there, was bone dry
possibilities I can think of are bad PCV, turbo seals gone, also hearing a ticking noise, I've heard the turbos can do this if they're gone.??
Any help appreciated!!!
THanks
THanks
