559/706 (RPE girdled 109, 9.0 JE, ATR H-beam rods, stock crank , ported irons 1.77in 1.5ex, ported stock intake, 212-212 comp roller, 70mm TB, KB plenum, RJC powerplate, 1.625 plenum spacer, 83 lb injectors, stock MAFS -1 screen , Turbo Tweak chip, old SMC alky with single nozzle, Precision FMIC, welded ported and dowelled stock manifolds, 3.5 dp, T72BB p-trim, AC 9" 3000 stall, 200 4-R by me with CK billet internals, 8.5 rear with 30 spline Eaton carrier, Moser axles and an LPW Girdle. 559 RWHP, 706 RWTQ. 21 mpg)Posted sig because it will be changing soon. With 25.5 psi, 24 degrees, 110 octane. A/f ratio was 11.3:1. Wanted to go to 29 psi but couldnt with wastegate configuration i had that day. P-trim turbo and stock screened MAFS killing the combo. It was done on the stock ecm though and the converter was eating up a bunch. Worked GN1's, forged crank, FAST SFI, 70GTQ and probably a new cam going in within 2 weeks after return from BG. Should go 650RWHP at 25psi with no problem if i dont drive through the converter and even more at higher boost pressures.
