BEATAV8
The Engine Whisperer
- Feb 14, 2002
Haha you know I do it. I like to use the meth on top of the E85 for the excellent detonation resistance and because it gives the primary fuel system a little extra room.
SignUp Now!Technically yes.sortta of on topic
I am in the pipe dream of trying E85 BUT my injectors are a little (a lot) on the small size @ 60# could the ALKY injection be used to stretch the injectors out some?
and
Help with pump E85 that tests below the advertised E85?
Tastes Great!Waste of time!!!
E-85 is still a primary fuel. Whenever you attempt to cheat, starve, or gamble with a tune and the primary fuel...EXPECT CHIT TO MEET FAN sooner or later!
Good luck!!![]()
Yep depends on how you use it.E-85 is still a primary fuel. Whenever you attempt to cheat, starve, or gamble with a tune and the primary fuel...EXPECT CHIT TO MEET FAN sooner or later!
Good luck!!![]()
Is it true that if you don't use it you lose it?Yep depends on how you use it.
Would this be where WB correction would come in to play?Jason makes a good point. Using alky flow to supplement a fuel system that's at 100% maxed out would be a risky business.
A safer example would be a fuel system that's at 85% with alky running on the sideline, and if the methanol stopped flowing for some reason then the fuel system could just pick up the slack and run at 95%.
YupWould this be where WB correction would come in to play?
How much gasoline does an ALKY displace?
Why would that be any different using ALKY and E85?
Twin #10 nozzles flow a lot of fuel.
