Who's Got A Good Tachometer Mount??
scot w.
GNSperformance.com
I'm interested in seeing who sells a good tach mounting bracket for the side of the instument cluster, above my scanmaster that is located above the climate controls. I'm not to crazy about puting big screw holes in my dash. pic's would help ALONG with where to buy the brackets to mount it. thanks, scot w.
scot, send phillyturbosix a PM, he's got his mounted up really nice, no screw holes..you remove dash cover and the bracket gets mounted to the dash cluster..looks very clean when it's done
Here is how I mounted mine. I used a rear veiw mirror bracket.
HTH,
Scott
Not to bad! looks good. keep them coming guy's I need the ideas.
Just got your PM been crazy busy this month.. Go to Home Depot.. but a cheap piece of metal.. Bend it in a vice so the tach is aimed the way you want.. drill a few holes.. paint it black.. mount it up. Leaves no marks in the car and it's solid as a rock. Don't shake don't bounce and it's the cheapest tach mount you'll ever have!
Enojy!
Tach mount
Thanks Jim, looks great this is what I was looking for. ;)
No problem Scot! Make sure you mount the tach to the braket and see where you like it to be by sitting in the seat before you pick a place on the dash to screw it to. I bent mine a dozen times to get it just perfect. At the slightest glance I can see the tach perfectly! :)
Check out Nick Micale's setup at arizonagn.com click on "new products"
Slick setup that utilizes the cigaratte lighter hole.
Here's what he's talking about.
I'm thinking about purchasing one of these for my car.
I'd like to hear some testimonials before I do.
Oh and how much does one of these tach mounts cost?
I temporarily velcro'd mine to the column to see if I would like them in that general area. I am gonna get some alum bars from home depot and bolt them from under the dash and they will run up and over the column to display gauges. We'll see if it can work or not.
