GBGN1
BP Performance Transmissions LLC
- May 26, 2001
You ever bother to study a 3100/3400 set up? Like I said I can change pulley size for more surface area on wp. After the headers are done, which will be soon . If it needs a change I'll do it. Thanks for the support.In studying the pic better...I would remove the idler pulley and come directly off the crank, and go around the pump and then under the tensioner. You need to find or modify a grooved pulley for the water pump and it should solve any issue you have.
