I think I can help some with this. I did a lot of research on the header design a few years ago and found that a stepped exhaust system is the best way to go. 1.5" primaries on the both sides into a 2" cross over to start. About 2/3 across increase it to a 2.125" diameter. On the passenger side increase diameter to 2.5" so the exhaust will expand and let the turbo to spool better. Look at some of the stepped headers that are used in the faster Buicks and you can see what I'm suggesting.
That's why the primary tubes are small and the crossover and passenger log are stepped up slightly. The exhaust cools some in the crossover and is re-ignited once it gets to the passenger side and a larger tube on that side helps with the expansion to speed the exhaust up some. Let's not hijack this thread anymore so we can see how things are coming along.Charlie doesn't expansion cool the exhaust or is it non existent due to the velocity of gases going through the pipes?
Ya they are very short, and the exhaust ports are so low in the head as well that I was actually kinda concerned that a nice set of headers would even be plausable befor having to make the turn for the crossover section in the oil pan. Luckily it all fits together goodThe series 2/3 engines are basically a short deck Stage II for street use. The only thing that would be nice is if it had the extra head bolts like the stage II block and heads.
That's awesome. So with the build these things can produce serious power and not have to worry the block failing.The series 2/3 engines are basically a short deck Stage II for street use. The only thing that would be nice is if it had the extra head bolts like the stage II block and heads.
Not worry as much, but they can still break. The blocks use cross bolted mains so it's a much more stable block.That's awesome. So with the build these things can produce serious power and not have to worry the block failing.
