WH1_T-Type:
Good Catch, I'll keep an eye on those.
SHADOWII:
Nah not really, I'm running a N/A Regal and didn't see the value in adding them.
I have one feeler open in the "parts for sale" section
scojack_2001:
I can use them, pm me a price. Do you still have the bolts/nuts?
All:
The reason I asked is cause I see listings on fleabay for S10 LCA's stating they will work on G-bodies.
So I looked on Rockauto.com and like most other Chevy parts they can still be had brand new.
Trying to get an early start on my never ending project list for this car.
So I decided to redo the front suspension. Just the Springs, Shocks, and Stabilizer Shaft End Links.
Well daddy is getting owned.
Shock --> Had to cut the top nut off (expected) and one ear off the lower part of shock (J-nut spinning)
Found the correct replacements from Auveco for the lower J-Nut and Bolts. Had to buy a box 25 of each though.
Stabilizer End Link --> Once again had to cut the top nut off then needed a impact to spin it free.
After getting all that apart I finally got to use my GM Factory Spring tool on the LCA.
Nuts came off easy enough, had been soaking a few days in penetrating oil.
Rear bolt spun out but the front bolt is seized into the bushing. Plus it's sorta hard to get anything on the bolt head since
the outer tie rod blocks a straight shot.
So I'm going to have to cut the bushing. So I figured I'd get another set, prep and paint them to they are ready to go.
