cecil bass
- Aug 27, 2012
Will these parts get me to 600HP with a good tune and work well together? this is my first TR engine build and i want to make sure it all done right . i might take it out to bandimere , but i know nothing about track racing so its going to be a street car. any info will be takin and noted !!! i want this build to last for years since im selling my 2011 camero ss w/ 7300 mi to have all this done ( the wife is making me if i want to built this car)
thanks all!!!!
Wiseco Pro Tru Forged Pistons and Rings +.030
3.400 4340 Steel Forged Crankshaft
Scat 5.970 Steel Forged H-Beam Connecting Rods
215/215 Turbo Buick Ductile Roller Camshaft
Weber/Morel Roller Lifters
COM 269 Cam Button
Double Roller Billet Timing Chain Set
Dura-Bond cam bearing
Calico Coatings Rod Bearings
Calico Coatings Main Bearings
SFI Approved Solid Billet Steel Balancer
Ported and Blueprinted Genuine GM 3.8L V6 Turbo Buick Timing Cover
Champion Ported Iron Heads w/ k-750 roller springs 8 bolt
T & D Roller Rockers
Full tubular Suspension
Headers (not sure which ones yet)
All new exhaust ( not sure which one yet)
hi-output ignition coil
#65 injectors w/ chip
Oil Pump Kit, Hi Volume
RJC Racing Billet Aluminum Pulleys
#IC-315-XTF Megacooler intercooler
RJC Airflow Distribution Power Plate
block girdle w/ old scraper, old shield
alky control system
full tranny rebuild (not sure what to do here and who to take it to)
4 inch up pipe
70mm TB
Idle Air Control Valve Angle Boss
APR bolts kits – front cover, intake, head studs
Biggie Oil Filter Adapter
RJC Racing Deep Sump Oil Pans
RJC Racing Rear Motor Brace
ZDD plus
Expert tuning ( still not sure who to take too)
Scanmaster
aluminum driveshaft
Comp Turbos CT4 6765 - 360 Billet Turbo
thanks all!!!!
COM 269 Cam Button
alky control system
4 inch up pipe
70mm TB
ZDD plus
Scanmaster
aluminum driveshaft
