Dec 14, 2008 #1 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,202 Can I fit wilwood 11.75" rotors and dynalite 6 piston calipers on stock Ttype rims using the wilwood application from 1982-1992 Camaro
Dec 14, 2008 #3 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,202 Thanks Gino.
Dec 15, 2008 #4 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,202 I am still looking into this though
Dec 15, 2008 #5 G GinoRin Member Joined May 23, 2001 Messages 364 you're wasting your time, norbs. the 10.75" kit has under a 1/4" clearance from the wheel to the caliper.
Dec 18, 2008 #6 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,202 You only need about .060" clearance I am trying to order a custom kit. I will keep you updated.
Jan 9, 2009 #7 F Fuelie600 Active Member Joined May 25, 2001 Messages 1,847 Any updates? I'm looking in to upgrading my front brakes also. Either Baer, Wilwood, or Brembo.
Jan 9, 2009 #8 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,930 I have the Baer 12" single caliper Sport kit with 15" AM. Racing AR-23's. They fit just fine. I think the T wheels fit them also, might need a thin spacer though. I can double check in April when I uncover that car. Not light weight but fully streetable. Jack Cotton should know what kit fits with what wheels and offer a good price.
Jan 11, 2009 #9 F Fuelie600 Active Member Joined May 25, 2001 Messages 1,847 I decided on the 11.5 Baer set up. They have the aluminum hat w/ riveted friction disc and are cross drilled, slotted, and zinc coated. I got 'em from Jack.
