This is not mine, it's a customers. He does not post much so I will leave his name out. If he chooses he can post here. This car has about 130k on it. The engine melted a #4 piston and lost compression. It also had a flat cam, the worst cam gear I've ever seen although it did not jump time. Showed signs of being run hard and put away wet prior to his ownership. We are going with a mostly stockish set up with some smart mods along the way.
