WTB 20 bolt oil pan
CTX-SLPR
Howdy,
I'm looking for a wasted 20 bolt oil pan. I only really need the section under the timing cover so if you've got one that the sump has rusted out, you jacked the engine up on it, or otherwise made it unusable on a motor its what I'm looking for.
Also price checking/sorta looking for:
Complete LC2 EFI gas tank, pump (stock is fine), and hanger/sender assembly
7.5/7.625in A/G-Body 10-bolt with a 3.42 or 3.73 gear, posi not required.
FE4 Steering box (stock T-type)
WS6/GTA/1LE sway bar (36mm hollow)
FE4/F41 rear sway bar (22mm)
F41 chassis bracing
Short nose 78-80 Regal 2Dr, 78-84 Regal 4dr and Wagon, and 78-81 Century Aluminum hood and decklid
$28 shipped if you want it. Ill get it out when i go ship some other items within a week.
I have a 86-87 YAYA steering box from a 86-87 turbo regal, and the stock rear bar off my 87 turbo regal limited.
Id make you a hell of a deal, let me know if you are serious about buying them
BW
