WTF car idles like ****!
those links don't work- they are incomplete.
and you don't need anything more than a simple Hayden fan relay kit that you can buy pretty much anywhere to turn on the fan(s). i got mine at a place called Mills Fleet Farm. the relay and wiring kit in my car is made in the USA, cost under $30 and came with enough wiring and a good name brand (can't remember the name right off hand, but it's good) 30 amp relay. i just added the wire to the ecm plug in the proper location to control the fan and used that terminal to ground out the realay. my turbotweak chip turns the fan on at about 175 degrees.
Well I ordered them already so just waiting on the harnesses novaderrick which pin in the ECM is it u hooked up to to activate the fans ?
Ok fans are hook up and running strong so that takes care of the high temps I fixed my vacuum leaks so that brought my Blms down to 128 I still don't have any iac counts after 10-15 mins of car idling here are the latest scanmaster number readings
074
AF 07
L8 43
Bat 13.8
Int 128
Bl 128
Mph 0
Clt 185-190
ATS 71
R 1050
Tps .46
IAC 00
Cc 90
