Tried another cam sensor cap and the results were the same. Cam Sync numbers just moved everytime I hit the gas. I verified that the cam sensor was tight and it is definately tight.
As far as the coolant temp staying at 164, it does stay there most of the time and it is hotter than hell here today. Seems a little odd. It did start low when I first started the car, I believe it was 90 something and the numbers slowly went up until 164. Then I finally got the car to be able to move down the road (sputtering) and the temp went to 166 but didnt change from there. This coolant temp sensor is new. Do you think the calibration is off in the XFI?
I did also adjust the injector opening delay to "0" and the inductive delay to 40. After doing this, the car did feel a little better, this is when I was able to get it on the road. It still sputtered though.
Any ideas?
Any ideas?
