SignUp Now!Bob i saw the 71 hpq for sale. I can't run a billet wheel turbo in the local 8.5 limited class.
The new TSM seems to be getting out of hand. More like small turbo TSO. All the fiberglass parts, large weight breaks proposed for the already fast bunch, losing the street equipment, and exhaust.
I say 3300 for iron head 109
3500 aluminum head 109 and 3800's
3600 stage motors
3bolt turbos only
no penalty for E85 or alky injection
keep all other existing rules namely all street equipment and exhaust.
I will wait to see what the final verdict is.
for what reason
3600 stage motors
3bolt turbos only
Somebody give this man a prize!!!!!! He hit the nail on the head.The way I see it is we have a rule that states the rules will only get voted on & changed every other year so nothing should be able to change till 2013. I only made one race this year so I'm sure I don't have much say in it but I did spend a good bit of time & money last year getting my car to fit with the rules. Now I will be forced to spend a bunch more money & strip my car down to lose weight, otherwise I will be leaving alot on the table. Seems to me the car count was just starting to go up (10 cars at BG) & now Will starts this whole thing about allowing stage blocks in TSM but he won't even be racing? Do as you guys wish & see what happens but I'm afraid every time you change the rules you just put people back to working on their cars.
I say leave it 3 bolt as it makes tech on the turbos much easier. 4 bolt stuff just becomes even more complicated.
Nothing Negative here. I think its a positive move for this class and I think Jason is sporting a Brass Pair for stepping outside the box. I am just Stating my case. Unfortunate for me as I am only fella with pos 3800 so I am on my own. Falling on deaf ears so I am done.
If the rules are not written I will plead the case. 3800 Series 2 and 3 are improved versions of the 109 engine. For those who do not know were installed in most GM FWD cars in 1995 threw 2008. My observation is as follows. The block is hi nickle with 4 Bolt Mains and steel main caps. The oiling system is improved as is the cooling system. The Heads are symmetrical and come with larger valves than the 8445 heads. The heads more than likely flow better than an average ported iron not even close to ported aluminum. There are no aftermarket cranks so the stock cast 3.400 crank will need to be used bringing the CID to a whopping 234" The intake is restricted to FWD or F-body cast intake. (Since sheet aluminum would not be allowed) The heads bolts are 4 per cylinder 12mm slightly Larger than 109. Not 6 per cylinder like a stage engine. The short block is stronger than 109 but not as strong as stage. I agree and understand the 109 needs to get any break that is available. I also believe this little engine could be a viable option to the Buick Performance community in the near future. I do believe the strength of the block and possibly the improved cylinder heads that weight should be added. I think a fair weight should be 109 aluminum weight. The 3800 does not have the CID capability of the 109 or the head flow capability of the LC2 Aluminum Heads. Since I feel performance wise its in between iron 109 and aluminum 109 I would think aluminum weights would be a good starting point. If we know that weights will be adjusted for fairness I would think there is more if a case to start at the lower weight and add from there. I would like to say that the 3800 rule would bring in more cars but I am sure thats not the case. I only know of 3 running cars with them and I think I am the only one that is looking to run at this level.
Ill use the LS excuse. IT's CHEEP.Lonnie what is the expense of putting this combo in a TB? There has to be some type of advantage or you wouldn't try it.
Joe, if you ever go junk yard hunting, turning up a 109 block is getting hard. These series 2 engines are a dime a dozen at any yard. That would be the main reason. Plus the blocks look a little more stout and come with cross bolted mains and what looks like billet mains already. Stock pistons are junk (going off what the s/c 3800 guys tell me.) Not sure of rods and crank though at this point. biggest hurdle appears to be it's fwd trans bolt pattern and headers.
Man I can't wait to see this.Lonnie will be selling the series2 turboThis is correct. They do look stronger and are a dime a dozen (GM Built 25 Million). Nothing has been proven as far as strength or performance. If you look in the 3800 world they go much slower than the LC2 with similar mods. They dont break blocks but again you dont see many TSM HP 3800s. We plan to find out in 2012.
Yes, Lonnie and I have spent countless hours doing R&D work on puting together a Drop in kit for the 3800 series 2 engine. Plans have been sent to china and parts are being produced in the finest of sweat shops by 10 yr old children for our buick enjoyment. LOLMan I can't wait to see this.Lonnie will be selling the series2 turbo
Buick drop in kit in 2013
