SignUp Now!I got a question, why 100lbs for an on center compared to an off?
What's wrong with 3550 s2 with production heads and 3650 with s2 heads?
Trying to eliminate Don Cruz style TSO engines from running away with the class..
Don't understand why an on center gets penalized, stage blocks in general for that matter. What you are saying is you can take the heads, cam, rotating assembly, headers, intake and turbo off your 109 and put it all in/on a stage block, and the stage block will go faster. Not going to happen, so why the weight????
I can understand weight breaks for iron heads, as the heads effect on power output, but a block is a block as far as producing power is concerned.
Don't know if you saw the other thread, but the penalty is because one can push the s2 harder plus the possibility for more cubes
What other rules will be kept?
I was wondering about the wastegate plumbed back into the DP rule.
Jason, I applaud you for looking at a way to help TSM grow. Some thoughts to think about:
We have allowed alcohol injection in THS for three years now with no weight penalty and no alcohol car has been dominante, so why add 100 lbs to these cars?
I do think it should be allowed in one way or the other.
I think #3100 for a 109 and iron heads is to light. I know you said above you talked to iron head racers who had to add weight but were they adding 50 lbs or 250 lbs?
Big difference. You mentioned allowing more light weight parts in the rules to help people get there. My opinion is the more race car parts allowed in the class the more it will hurt the class. Seen it happen before and do not want to see it again.
Take care, Kip
I think this is a good idea. I was all about racing Tsm this past year until I broke the block and built my stage motor. This would allow me to come back and play with some of my buddies. The only thing I have a problem with is the weight for production headed on center blocks. I think it should not matter if you have on/off center blocks with production style heads. .060 shift in a block will not make you faster. I understand you do not want the tso motors to come play, but most of the guys are alot more than a turbo away from switching to tsm if this happens. I am up in the air at the moment on what I am doing with my car as there are alot of local races happening next year that I cannot make my car fit into to easy, so possibly selling the car for a car that fits better. I am watching this to see the out come to help aid my decision.
Also what about the use of other factory production blocks such as the 3800 series 2 & 3 motors from the fwd cars?
