You want to log your fuel pump voltage with your XFI 0-5 volt input
norbs
Classic fast, XFI, SPortsman & MS3 programming
Hi if you wanted to log your fuel pump voltage for example with your XFI, but you only have a 5 volt input you need to build a voltage divider network, and connect to your analog inputs to lets say 16 volts in =5volts out
You can use the following online tool to build this...
http://tuxgraphics.org/toolbox/circuit-design-calculator.html
what is the input impedance of the XFI aux input, as it will act like a resistor parallel to R2.
Regardless, be sure to use a voltmeter to verify/calibrate the reading.
Bob
FYI - This is the basic principal on building the volt booster to the alternator.
Allan G.
Bob
That is a good point Bob, maybe a adjustable high precision variable resistor to compensate.
