what is the procedure for this conversion? i hooked it all up and set it where it was supposed to be set all 4 dip switches on. the car started and idled fine. im using a pte chip. upon tring to drive the car it spit and popped ...........no setting would help ....any suggestions?
ps do i have to reset the ecm by disconnecting the power everytime i change a switch? i think this might be the problem.......also do i use the standard 43 w/ line off fuel pressure
