Getting here late, but…
Originally posted by MJRWOOD
At full boost the fuel pressure maintained 72-75 PSI throughout the whole run. As usual, she was popping at the top of third gear and Direct Scan showed third gear O2's in the 750's with lean pops dropping to the 600's.
Earlier on I believe you said you were running you static FP @ ~50# and ~24psi boost, with a 340 pump. At those pressures, if your supply voltage at the pump is ~13.0v, the pump is capable of delivering roughly ~60 gal/hr at static pressure, dropping to 48 gal/hr at full boost. Again, this is
pump volume, not at the rail, which is some 20' of twisty little crimped metal line, with tiny orifice fittings, later. Add that restriction and the efficiency drops. Dunno how much (at the monment), so don't ask. That line may have some corrosion in it too. If your static FP was reduced to ~45, the pump is capable of delivering roughly ~63 gal/hr at static pressure, dropping to 52 gal/hr at full boost. We did this on a friend's car and it helped eliminate KR.
BTW, Bruce mentioned his static FP was 42… at ~13.0 the 340 would provide roughly ~64 gal/hr at static pressure, dropping to ~54 gal/hr at ~24 psi boost. But, Bruce has also mentioned (elsewhere) that he provides more like 14.0 volts, so it could be as much as ~72 gal/hr at static pressure, dropping to 59 gal/hr at ~24 psi boost. Quite a difference, if my calculations are close to correct... you: 48 gal/hr @ WOT; him: 59 gal/hr @ WOT. Nearly 20%.
The fuel pump data was calculated from data listed at
http://www.autoperformanceengineering.com/html/fuelpump.html, and it is noted that this data came from Walbro. I have sent an e-mail directly to Walbro asking for data at 12.0, 12.5, 13.0, 13.5, and 14.0. hopefully I will hear back from them, but I'm not holding my breath.
Originally posted by TurboJim
He has the *right* amount of fuel being injected, the *right* amount of timing to sustain an RPM level and make the most power available at that level.
That's what I want to achieve, but I'm not exactly sure how, and I'm not a scientist so I don't completely understand everything, but I'm trying. One thing I do understand is that it is not beneficial to have the injector on all the time... now, how do I (& a lot of "we's") get it so that it isn't, besides detuning the crud out of it? If "X" injectors provide "Y" amount of fuel @ "Z" ms, which equates to "XX" pounds of fuel, which is sufficient to produce "YY" HP, but I can't, where do I start? I'm trying to me methodical, considering each element, but I don't know if I am looking at the elements in a completely logical order.
Modified ECMs and larger injectors are one part of the puzzle, but what if there are self imposed limitations that don't allow for it? For instance, I have limited myself to injectors that can work with stock ECMs so that if I am ever in the middle of nowhere and the ECM fails, I can get another one in a reasonable amount of time, like from an auto dismantler. Sure, it is feasible to just keep another ECM with me, but crimany, where would that logic end? Cary one of these, and one of those, and one of these, and one of those... no thanks. Granted, this may (will?) limit performance, but I'm not looking for "maximum", just "as good as possible" with what I have.
On one hand, we have guys like Bruce, making 450hp with 300hp worth of parts, Then we have the guys who bolt on 600hp worth of parts and make 300hp....who say guys like Bruce are full of crap. Who would you say really knows what theyre doing?
This may be the "Quote Of The Thread".
I'm somewhere in the middle, but closer to the wrong end.
Originally posted by bruce
If you poke around some, you'll see I've been writing about tuning, and proms for years, now.
Where else should I be looking?
This is something, I just do for grins, and a few friends.
Can I be your friend?
