SignUp Now!Will selective ring sets be available for these?Depends on the brand. The one's I'm finishing up start out and .001 over and in increments of .001"
Yup. Trying to get a ring that will work with some sizes is a no go. There's a crap load of options around 4". Not so many around 3.8"Oddly enough the rings are the trick. I've got almost more time tied up in ring brainstorming than I have piston designing. The way I've got the print set up, it's easy to interchange between 1.5mm and 1/16 ring packs. That way it's easier to stay cheep with shelf rings and still be able to get quality units. Couple in the marketing by ring manufacturers by using stuff like 'file fit' with no specs for printing stuff like '3.830 +.003" instead of just saying they are 3.083". Fortunately we're dealing with power adders so it helps that we need gaps that are a little more loose. That helps when it comes to honing to 2or3 more than a 'normal' size.
If it wasn't for having to work around rings, I'd say you can get these slugs in any size you want down to a few microns.![]()
