For a high ten combo I would go with the big single walbro pump with the racetronix Teflon lines. I think these other combos will work fine too but the big single pump is simple with extra capacity especially if voltage is boosted. Plus it is factory engineered for E85. And the teflon lines are priced very reasonably for what you get.
The Racetronix fuel line kit and 416lph with AN sender is on my X-Mas list.
For now I will continue to use my DW300.
Not looking to go faster than 11s but will like to have some room to play if I go bigger down the road. I have 80lbs Injectors right now as well.
25# of Boost 3rd gear and my inj dc is already at 86%. Base fuel pressure of 50lbs. Might bring FP up to 55/60.
