Why do you say 0.002" is too much for a performance turbo V-6 build?
That is what the BPS specs states in the turbo section.
Most custom and race engine builders usually determine bearing clearance based upon journal diameter and use, the factory specs are used as a guide, or starting point
Your new bearings clearances are way tighter than we ever do, even for a
street build. With 0.0010" total clearance on the crank bearings, that will only give 0.0005" actual clearance when running.
We have built and installed MANY of these builds down into the 8's with both stock-type oil pumps and the Dut style pump, and have never lost an engine bearing because of too loose a clearance.
I have to give credit to Mike at TA, Ken D. and Mike Zimmerman who have years of experience in building race engines, all who have helped "educate" me over the years, starting with the 455 Buick V-8 engines.
You could also check with some of the other known, quality engine builders of turbo V-6 engines to see their view on this subject.
