hensleyt
- Feb 20, 2008
Can I build a engine that can do this without being a ticking time-bomb ?
And last the next five years .
SignUp Now!I have a good budget ,just not 10K
I ran a stocker for over a decade at 11.5 unbroke,drove it to the track and back.the tune is key.
Just because the block was line bored with steel caps doesn't mean it was done right. I would get that block measured by a buick guy who knows these engines before you put another set of bearings in it.No e 85
I've got agood rotating ass. .002 on mains
Bloke was line bored with 3 steel caps
200 is a little zealous more like 60 that's what I did the first year I started racing it
I'm in Hawaii its not that easy this is why I'm looking at buying a short block from a well known builder ,I'm sure his will be right Im just worried my tune is the problem( I dont think so)what im missing I just cant figure out
My rotating ass cam from a supper guy and shipping back and forth is tricky and $$$$
I think Im looking for reassurance that these little 6 can live at 11.5
not to bust your chops but this is very important you need to know.what afr and timing are you running?have you verified fuel pressure and alky fuel pressure?volts to pump?Tune I dont know ,its a 6.1 TT Alky chip untouched ,Alky controller set at 6
how are you getting the readings?you said kr at 5800 are the plugs being read with the car shutting down at wot?plugs look good ,not lean no detonation good heat range
