Yeah I have the same injectors too. I always use 116 race gas and have had no KR yet. I do have a scanmaster, thats all for now. But I see you have a dump pipe I dont have one yet. I am getting MT drag radials, I was getting 1.8 sixty ft, but that was with only 5psi launch. I am hoping for some times near that.
What as your Mph?
If the Nittos were 275/50's I don't expect it was much faster than 110.
The 49/44 is faster with 28" tall tires than 25.6" tall nitto 50's.
Was the car wanting to push through the lights at launch on 5 psi?
The best Launch technique is to hold 5 psi (or what ever the brakes will hold) then rapidly floor the gas and release the brake. This will plant the DR's. If it spins and you have to pedal it, put more air in the right airbag (never pedal a turbo car, WOT or nothing)
If you have a good exhaust, the dump won't help much, but if your exhaust is stock, a dump will help tremendously.
The potential of the 49/44 with the stock motor is pretty easy 11.7's @ 116, even with a stock intercooler and 23 psi of boost, but restrictive exhaust and Nitto 50's aren't going to get there.
