Madmustard
- Nov 16, 2002
Trying to track down the short from hell and cant figure it out.Drains the battery when car and key off.All started when changed this fuel pump to walbro.Dont believe its that because unplugged the wiring harness to pump and took hotwire kit off and still a short and draw..Short took the battery and alternator out but still has a drwa on system.
Checked volts to pump with stock wiring at idle its 12.6.With hotwire kit its 13.9 at idle..sounds pretty high to me what should I use stock or hotwire and with load will the 12.6 drop at wot???
