- May 26, 2001
Having to deal with ambient temps for months at a time that most of you never see, and having dealt with them for MANY years here in the desert, besides the 23 years with turbo Buicks, I would like to give my comments.
First, I certainly do not agree that running a turbo engine hotter keeps everything "tighter" and helps from blowing head gaskets.
As far as 35 psi with a TE-44 turbo, best to stay away from that guy's advise and comments, in 23 years working with these cars and knowledgeable owners around the country, never heard that!
I the summer heat, a big problem is the oil companies use a "summer blend" gasoline which is even worse than the normal crap gas they feed us.
As we all know, detonation is to be avoided for engine life with our cars, and the hotter the engine temp, the easier for detonation to happen, and the summer blend does not help.
Alum heads dissipate heat better than iron, so at the same boost level, less chance of detonation.
As far as engine life and reliability, oil also plays an important part as is does 30% of cooling the engine.
For the race cars with $20K or so in just the engine, engine oil temp is a LOT more important than cooling fluid temp. Over the years I have found that most racers want at least 140 deg. oil before a run, and would like to see it rise as little as possible. In my case I usually see under 200 deg. at the end of a run. Coolant temp would be 170-180 deg. then.
If salvageV6 runs only 140 deg. coolant temps, his oil temp should be 160-170, or maybe more depending on the length of the trip.
Some colder areas may not have sufficient heater/defroster output for cold winters, so a higher temp thermostat would be appropriate there.
