SignUp Now!opening up the two inner headlights will do nothing to help with cooling once the car is moving- in fact, it may hurt it a bit.. you want to get the air pressure in the engine bay side of the radiator as low as possible to help air flow thru it, but the open headlight holes will just add air pressure in the engine bay. it will also add more aero drag and front end lift to the car at higher speeds due to the extra air that you are dragging around under the hood.
if you want better cooling and a little help with the aero on the car, then hood and fender vents are the way to go.. the Lumina Z34 hood vents look good on a G body and actually work according to that one guy that runs his GP 2+2 in top speed events.
Were you able to use the stock cat hanger with the Gforce crossmember? I'm installing mine this week but it doesn't look like its going to fit.
This damn g force crossmember is giving me a hard time! About ready to give up on it. How many exhaust mods did you have to do to get it to work? It's not even close on my car.
HelloBozos;2911641I've been told anywhere from 60 hours to 600 hours....I'd like a more defendant answer if at all possible.this build would be great example said:HelloBozos, That is a really loaded question. I have done a few frame-offs for people and myself. And to quote it."It really is a blank check type of deal or nothing." I'm sure dsapper will have some Close hr.#s. But the running changes, the custom fits, or have to make the part. Just can not be figured in. The shipping and expedited shipping alone will boggle most. The last one I did we had over 3k in extra fittings and nitrous stuff left over. Most the items have to be built/ fitted/ removed tweeked /refitted/ removed/ sent to plater/coater and hope it all still fits or works as intended.
dsapper, just went through this thread, WOW beautiful build.
The problem is the "while we are at it" mentality. I probably have 250 hours in it all and all. After paint the interior and stereo will be by me so not sure on that time. Its impossible to guess depending on what level of quality you want and how creative you get. Its very easy to get carried away
Not to mention the condition of the vehicle. Once you take the frame and interior out it can completely change the plan. It doesn't even have to have a lot of miles on it. It's completely subjective and as I tell people when doing electrical work, it may take me 5 minutes or 5 days, and I charge by the hour so sometimes it can get outrages.![]()
