SignUp Now!Does anyone know the interchangeability on the door jamb vents between GM cars? Will a 2nd gen camaro vent fit our car? They look the same
Has anyone tried to install the Fay2 unit on a TR with shaved frame rails? It doesn't appear to work with the frame mouting.
Conrad
If you are going to be running track days with the car I'm interested in what you've found regarding cooling and oiling.
On cooling: Do you plan to run a differential cooler? What type of trans cooler are you going to use? High power at sustained RPMs = HEAT!!
On oiling: what is known about how well these motors do with oiling under high g load? Does the factory wet sump work well enough (on sticky tires) or is a dry sump needed?
I run track days with my C6 vette and am really intrigued about building a similar TR (even if it's not beautiful like yours) for track days. My experience with the C6, though, suggests that conventional wisdom for drag racing doesn't necessarily hold for track days, where sessions are longer than 10 seconds and RPMs stay high.
And thanks for this thread!
A nice aluminum alternator with dual fans,
Where did you find such a thing? And do you have a pic as I'd like to see this.
 . good news though I found two intact tta hood vents with screens and they are on the way
. good news though I found two intact tta hood vents with screens and they are on the wayLooked fine or actually measured fine? This simple deal can cost you your engine. Road course racing puts alot more demand on oil control than meets the eye. You've put alot of work in your car and I'd hate to read about a spun bearing from high G turns/braking. I would suggest pulling the pan and adding a front baffle (at a minimum. Your shop can tack weld it in in just a few miuntes) and verify that the pick-up screen is .275"- .375" from the bottom of the pan. (also use a cork gasket with a layer of the "Right Stuff" on both sides for a no leak install.)
