1989 TTA
Tranny is fine in all respects except 2-3 gear WOT shifts. I have adjusted TV cable correctly and when i get the right shift feel in all gear changes the 2-3 will not shift unless i let off gas a little. if i take the cable out (lengthen it) all shifts get soft but third will then shift at WOT.
the trans is an 8 year old rebuild and i have encountered this problem before a few years ago and was able to finally get it tolerable but i guess it has adjusted itself cable or something and it seems i can not correct it this time.
any ideas on what i can do to fix this?
