Junior Samples
Walk Away
- Aug 3, 2007
ttt
Any chance this would work on a Series 2 FWD engine? Uses similar coil pack and module setup, it would be awesome to have something like this for launching consistantly.
bob, i see this in the manual
The inputs have spike suppression built in, but it is not recommended to connect them directly to a trans-brake solenoid. A relay is recommended
i was thinking of connecting the two step in line with trans brake button. This would send 12volts to the 2step box. is this a no go? i wasn't sure if your saying don't wire it to the trans brake solenoid in the trans but the button is wired to it.
other then my one question the manual looks great. the diagrams will help but its pretty straight forward and i think i can do it without them. anyways thanks for the update its looking killer
Thanks Bob,
Here is a wiring diagram for a 2000 GTP ignition control module to sensors and PCM.
http://members.shaw.ca/slofiero/Wiring/ignition.gif
And here is a zip file with what should be all the PCM wiring
http://members.shaw.ca/slofiero/Wiring/2000GTP.zip
Cory
man its good practice to use relays on your tbrake and nitrous anyway.its less load on the switches to hold up a relay then to hold the big solenoids up.also you get the full 12 volts to the solenoids this way as well.or at least this is what i was told and have always done it.bob, i see this in the manual
