2001 ss camaro 10 second na car
esm
engine: 408 iron block -eagle rods and eagle h beam rods -l19 rod bolts and je pistons - short block built by wolfe race engine
slp oil pump - magic stick 3 camshaft - comp cam push rods
high flow heads ported and polished 243 casting heads --over 3k just in prt work --ferrara valves and psi springs -
fast 102 intake and fast 102 throtle body
ls6 fuel rails with 42psi injector and 255 intake and 340 inline walbro fuel pumps
trans--4l60e --has billet pump gears -billet servos-and billet forward drum - heavy duty overdrive bands-raybestos z-pack clutches harden input shaft and modified valve body built by trans pro ----3500 vigulante converter
rear end --moser 12 bolt with 35 spline axle - 3.73 --detoit tu lock snf girdle
(car passed emission)
nitrios dave 102mm throttle body --chrome nos bottle nx solenoids --tps sensor activation
lingenfelter box and msd wire
slotted and cross driilled rotors
pioneer sound system
ac blows cold
speed inc tuned on 17 inch ss wheels car went 10.90 never been sprayed
call or text 773 491 8806 ---cash only can send pix ----$12500
Damn I'm jealous! Where are you located? I'm in the Huntley area. If you still have it in the spring I might be interested until then here's a bump for ya!
