What could cause a 2004r to pump itself dry thru the vent tube? The trans was not over-filled, nor was it hot. This happened immediately after starting engine (cold start), i noticed a huge puddle on the garage floor. I will say the trans has in the past been known to spit a bit of fluid out the vent @ WOT, but now it's pumped itself empty @ idle. I did verify the fluid was not coming from the cooler lines, pan, or front pump.
Thx,
Thx,
